Changing from 880 to 440's injectors
burmese434
Post by burmese434 »
Im using the tune on here and when i change from 880 to 440 whats the best way to adjust.. Should I change the overall fuel trim?
First change the injector size and then make adjustments to the overall fuel trim, then fine tune the tables.
burmese434
What number should I choose like -20 or -10? for the overall fuel trim
You have to use a wideband and measure the air fuel ratio to know what to change.
