when in open loop idle goes up and down?
Rockman
Post by Rockman »
I have a B18c with a Skunk2 IM, holley 68TB, 750 inj, 9:1 compression pistons, manley rods, MSD distributor. The problem is when I put my S300 in open loop to tune the idle goes up and down, up and down. When I put into closed loop it idles fine. I checked my IACV ohms at 11.2 set my TPS at .45v. Still idles up and down in open loop. I tried a fresh calibration with no help. Is this a ECU problem? Please help! anybody.
Johnny_9
Cams
Post by Johnny_9 »
Cams?
S /mgr - what version? v1.4.8?
Rockman
Post by Rockman »
I'm running GSR cams, S300j v1.4.8 Idles smooth on closed loop but when I go to open loop about 5 seconds later the idles goes up and down a/f goes rich 12 to lean 17. I checked my Iacv its good, my coolant is bleed, my TPS is set correctly @ .45v. Timing is set to stock settings. I even tried a new stock calibration and adjusted my injectors. I recently downloaded the new v1.4.8 could this be it? Do I need to adjust anything? Spunkster where can I get the old version 1.4.7 to rule out my problem?
http://www.hondata.com/forum/viewtopic.php?t=3772
You should never go back to an older version.
Rockman
Post by Rockman »
This is my open loop and closed loop datalog at idle with a little reving. Please help with suggestions why my B18c idles like this and what can I do to fix problem. Your help is greatly appreciated. Thanks Mahalo
You have posted calibrations, and not datalogs. without the datalogs it is impossible to see what is happening.
Rockman
Post by Rockman »
how do you post datalogs?
Rockman
Post by Rockman »
can anybody help me out on how to post datalogs? Thanks
Johnny_9
Post by Johnny_9 »
menu : datalog....see the help man...
Rockman
Post by Rockman »
Thanks bro I'll try it tonight. Mahalo
