help can't get af over .80
aavery
Post by aavery »
jdm b16a stock , in an ek swap, fpr 34 psi, 180 psi compression across the board
runs rich all the time, check and can't find any leaks attaced is map and data log hondata s300 with plx wide band
i have cut 20% of the fuel and still runs rich
Use a different input for the wideband such as the ELD input.
aavery
Post by aavery »
eld 10 is the wide band
Luke
Post by Luke »
aavery wrote:eld 10 is the wide band
in your calibration it isn't.
change it and do another datalog.
best regards Lukas
aavery
Post by aavery »
thanks works perfect now, i am guessing that the two signals were conflicting :D
