Speedo goes right to 160mph?
HinckleyDSM
Post by HinckleyDSM »
Its a 05 type s with kpro. Once my rsx starts to roll the speedo goes right to 160mph? Any ideas on how to fix this problem? Have been told the vehicle speed sensor but I replaced that and it still does it. Please let me know.
Steve
mkulak
Post by mkulak »
You need select off the following button in the MISC parameters section.
HinckleyDSM
I just hooked the computer up to it and I got to that screen but it wont let me change anything. Its says something about the ecu being an older version or something and I have to re-calibrate it? any ideas?
mkulak
Post by mkulak »
Never seen that... Have you tried loading a new .KAL or Basemap?
HinckleyDSM
No I have never done anything like that. Should I try and do that? Im a DSM guy and dont know anything about Kpro
HinckleyDSM
it says "The calibration in the ECU (1.2.8.0) is from an older version of KManager. Please upgrade the ECU calibration before datalogging from this ecu"??
Click on New Calibration and open the 05 RSX calibration and upload it to the ECU.
HinckleyDSM
vehicle type: rsx (type s)- PRB
then for calibration i click what? it has so many to choose from and there is only one that says 2005 with 310cc injectors, intake, etc... Is that what I use?
HinckleyDSM
anyone have an ideas? my rsx has peakboost kit, 35r, 780cc injectors, 3in exhaust, etc..
Make sure that whatever calibration you use you have the check next to countershaft driven speed sensor.
HinckleyDSM
I just dont understand what calibration to use??
HinckleyDSM
The car was tuned by the original owner so I dont have that calibration. So if I pick a different calibration will my tune be all messed up?
Your only option would be to try and download the calibration from the ECU by going to Online, Tools and download. This may or may not work, but it is the only way you will be able to get the calibration that is currently running. If you can download it then make sure you save it to your laptop.
HinckleyDSM
Ok I got it to download from the ecu and I saved it to my computer. Now what is the next step? Sorry for all the questions just trying to figure this out. Thanks
Axix23
Post by Axix23 »
now try uploading the KAL to the ecu..
