Help about donor ecu
Harrytyper
Post by Harrytyper »
hi, i have an european Civic EP3 with PRA ecu but i'm a little bit scared of sending my original ecu to be modified so i'm searching for another ecu to be disassembled, doesn't matter if i loose my immobilizer.
which ecu can i use??
RSX ecu, japanese EP3 ecu.. etc
thanks
You should use the CTR ECU. Due to the cost of this you will be better off just using your original ECU for the K-Pro. Just make sure you insure your package when you send it. The chance of it getting lost or damaged is VERY small.
cpl racing
Post by cpl racing »
You mean KPro Matt, must be working too hard!!!!!!!!!!
Spunkster wrote:You should use the CTR ECU. Due to the cost of this you will be better off just using your original ECU for the FlashPro. Just make sure you insure your package when you send it. The chance of it getting lost or damaged is VERY small.
Hondata, Jackson Racing, Gruppe M, Dyno Dynamics
