PNF k pro
tazmania
PNF k pro
Post by tazmania »
Hi
Does a k-pro modified PNF ecu (02-04 civic SI) fit a 04 Euro type r?
To run properly in closed loop you will need a different Primary oxygen sensor and some wiring changes to make it work.
tazmania
Post by tazmania »
I ordered a wideband sensor from denso, but can anything can b done for the 6th gear security pin? Not to shift the reverse by mistake and brake my gearbox, because the PNF is a 5 speed ECU
Thank you
If you need the reverse lock out then you should get a PRB ecu instead.
tazmania
Post by tazmania »
Can't we do any wiring to give a signal to activate the reverse lock???
because i've heard that we can switch the wire of the reverse cable and put it a the nitrous switch and activate the nitrous from the kpro and it will work. anybody heard about it? or can i activate it manually?
