probem with output ground ports from ecu
Street Dreams
Post by Street Dreams »
nevermind
Martian
Post by Martian »
My money is on your testing/using the wrong ecu pin. Go to the help file in Smanager, contents>ECU connectors. Go off that, and remember what it tells you for visual reference at the top.
thank you, thank you, I'm here all week
Street Dreams
sorry nope. i ohm thru the wire for the purge valve a20 all the way to the ecu plugs and had no problem. I know what plug spots go where. My question is does something affect this ground outputs. because i find it very strange that none of my ground ports work, and they did before. the only changes i have made from the last time i used the nitrous over 2 years ago was hooked my wide band up to d10 eld.
The datalog doesn't match the calibration.
