is there a need to tune for fuel at part throttle
packrat555
Post by packrat555 »
It is my understanding while the ecu is in closed loop it will automatically adjust for fuel except for when you are in a wot mode.
If this is true why should I bother adjusting for fuel if the ecu will effectively do it;s own thing.
You still need to tune it properly to that it is running close to where it needs to be in open loop.
tricker_luke
Re: is there a need to tune for fuel at part throttle
Post by tricker_luke »
If the fueling isn't quite right, say up to +15% short term fuel trim, what problems might this cause? I've read people say short term should be about 5% or less
If it is off by that much then you should adjust the fueling to get it closer to 0.
