Skunk2 TB for FD2R error on E throttle
fabiangt79
Post by fabiangt79 »
Hi,
I have changed to the new skunk2 E-throttle, uploaded with the latest software but i keep getting the engine check light on the faulty spring in the throttle body?
Has this anything to do with the new software?Changed another new skunk2 Tb still the same.
Previously, use the 1.1.5.6 sofware did have this issue with the E-throttle.
Can Hondata advise on this issue?
We have not changed anything in the ECU to do with throttle control. The cause is whatever you have changed in the throttle control system.
Return your ECU to stock and see if you still get the error code.
azrieazmy81
Re: Skunk2 TB for FD2R error on E throttle
Post by azrieazmy81 »
FabiangT,
I also facing the same problem recently. Have your problem solved? What is the problem cause?. I changed my ECU and reinstall flashpro as foreman cant detect the problem. For the time being seem ok. Hopefully problem wont occur..
