Question about "Use wideband input for closed loop"
sitinduk
Post by sitinduk »
I have a PLX SM-AFR wideband that I will be installing in place of the stock o2. Will wire PLX wideband output -> D10 (ELD).
If I check the option "Use wideband input for closed loop" in the Closed Loop Parameters, do I need to connect the PLX narrowband output to D14?
No you do not.
