Boost Controller Components, Codes, Voltage, etc.. what is i
HeitorVTiBR
Post by HeitorVTiBR »
The thing is, I have a Solenoid for Hondata Boost Control, but came without the components for preparation of ECU ... accurate data collection to buy here in Brazil and solder the components on the ECU
I know they are preparing for these items.
Large transistor (but which voltage? What data? Little information)
Small transistor (but which voltage? What data? Little information)
Diode (what data? Voltage, etc ...)
D14
220 ohm resistor (red / red / brown)
R70 (explained this okay, thank you, ignore)
330 ohm resistor (orange / orange / brown)
(Tá explained this, thank you, ignore)
Diode and used in binding 12v Solenoid connection with the A11 ...
1N4004 with the code, which his data?
thanks for the help.
We don't give out the idividual component information. You can purchase a component kit through any Hondata dealer for $10.
