Engine cuts out 6000, rpm, will not run until switch ign off
velocuaz
Post by velocuaz »
Hello,
Hope some one can help with this, first have a classic mini with a K200A3 engine and box, bought kit from Superfast minis with the ecu as part of kit, problem is when I get to 6000 rpm engine cuts out untill I switch ign off and on again, then it will run fine untill it gets to 6000 rpm again, engine is just stock unit, dose any one have any ideas ?
Many Thanks velocuaz
_Shift_
Post by _Shift_ »
By cutting out you mean??? Rev limiter?? stalls???
Do you have any error codes?
If so, fix them, if not, look at your wiring harness.
