When to Disable O2 heater
Johnny_9
Post by Johnny_9 »
The help doesnt explain in what circumstances the tune should disable the O2 heater. Can someone point it out or chip in?
When tuning. when you are done tuning put it back in closed loop. If the part throttle has been tuned right you should only have a few percent short term correction and and as close to zero as possible of a long term correction.
Johnny_9
Post by Johnny_9 »
Spunkster wrote:When tuning. when you are done tuning put it back in closed loop. If the part throttle has been tuned right you should only have a few percent short term correction and and as close to zero as possible of a long term correction.
Thanks. I was asking about the O2 HEATER. Appreciate any clarification.
Luke
Post by Luke »
o2 sensors work correctly, when they work in their projected temperature range.
the heater shall make the sensor work faster, since in circumstances, when the engine is cold (starting the car is the morning) it isn't warm enough to give accurate values back.
in other cases the heater just turns on to check if the temperature is right... if not - heating... if ok - don't heat.
just look at the heating sequence of your wideband... and you will figure out how that works ;)
best regards Lukas
Johnny_9
Post by Johnny_9 »
Thanks. Do all B-series have a a heated O2?
Luke
Post by Luke »
B16A1 don't have it, as far as i know... they have an one wire o2 sensor
best regards Lukas
Johnny_9
Post by Johnny_9 »
makes me think this feature was for the mix 'n match ecu/wiring and engine, no?
It is also there for those that run a wideband instaead of a stock O2 sensor.
