ecu swap
all-black
ecu swap
Post by all-black »
is it possible to run a th gen civic ecu in a new accord 09? the ecus have the same connections. if i were to make sure the cam sensors and crank sensor are the same as the si. then use fp to tune it
No this will not work as they have different pinout, different connectors and are completely different architecture.
