Launch control problem...
alexplicit
Post by alexplicit »
hi guys.
so i have just installed a clutch switch (brake light switch) and and set button up.
this is how i set the launch control. car on (running) press button once. bring car to desired rpm, quickly tap break. put foot on clutch car revs straight past launch limit.
it worked once or twice, but when i turned car off went back to not working. cant get it to work again. nothing has changed in the car. in fact car didnt even move. this is all within 20 minutes.
WTF is wrong????
Speed is a question of money... How fast can you AFFORD to go
What is the s200 serial number and was it tuned with Romeditor 3 or Romeditor 4?
alexplicit
S200-4029 no idea what it was tuned with
All I know is it's boost unlocked, and datalog unlocked. But I can't get it to connect properly, connects for a split second then says connection error
YOu must find out what software it was tuned with as that will affect how you set thigns and what software you can use to datalog.
alexplicit
What different types of estate there to set it up
alexplicit
just got hondalogger to connect. i had to raise the error limit to ten. i have 9 errors!?!?! and it does not show any real time information.
whats wrong now???
