Nitrous control?
Vtec6000
Nitrous control?
Post by Vtec6000 »
Can someone tell me which model ecu has the needed hardware to be able to control Nitrous as I have been told not all kpro installed ecu's has the needed hardware to switch a output.
Vtec6000
Post by Vtec6000 »
Thanks Spunkster. Do you if the needed hardware can be added to a PRC ecu?
No it cannot.
Vtec6000
Post by Vtec6000 »
Spunkster wrote:No it cannot.
Not what I wanted to hear aha :D
Will the arming input work on a PRC ecu? i.e If I was to wire a trigger signal to one of the selectable inputs would the fuel and ignition correction work? and I could just have a manual switch to start the nitrous spraying.
The FANC output can be used as it is not part of emissions controls. Have you tried that?
Vtec6000
Post by Vtec6000 »
Spunkster wrote:The FANC output can be used as it is not part of emissions controls. Have you tried that?
Interesting, so I could use B6 FANC output to trigger my Nos relay? I assumed non of the outputs would work with the PRC ecu but if that will work then great 8)
