EPS Indicator Popping up
IcEMoCHa
Post by IcEMoCHa »
Dear Hondata,
I drive a Civic FD2 Automatic 155HP Asia ..
I mentioned this before in another thread. While driving, the EPS indicator pops up once in a while then goes off again after a few secs when I'm running Flashpro calibration. It doesn't show up after returning to stock.
It's been bugging me for a while now.. And it's kinda annoying.. Also found another Flashpro user with the same car as me having this problem.
No errors show up in the datalog so far..
Any solutions to this problem?
Thanks..
First, are there any speed related errors with the FlashPro, including problems from the gear ratios being different?
Can you determine when the EPS indicator comes on? eg after a cold start, when driving at a certain speed, after a high load on the steering?
Finally, can you use a Honda scan tool to find out the error code and freeze frame data from the EPS unit?
IcEMoCHa
Post by IcEMoCHa »
Hondata wrote:First, are there any speed related errors with the FlashPro, including problems from the gear ratios being different?
Can't seem to figure out the cause of the EPS indicator..
How can I use a Honda scan tool to find out the error code and obtain freeze frame data from the EPS unit?
Do you mind guiding me as I'm still learning how to use this.
IcEMoCHa
Re: EPS Indicator Popping up
Post by IcEMoCHa »
Replying to the case above.. I have retrieved the error and the freeze frame of it. Uploaded.
Please solve this issue as soon as possible thank you.
I believe that it has something to do with the gear ratios causing the speed reported to the EPS being different than what it expects. What are your speed adjustment settings? Does the datalogged speed and speedo speed match the true vehicle speed?
IcEMoCHa
Post by IcEMoCHa »
Hondata wrote:I believe that it has something to do with the gear ratios causing the speed reported to the EPS being different than what it expects. What are your speed adjustment settings? Does the datalogged speed and speedo speed match the true vehicle speed?
I'm using -13% speed adjustment ECU and dash. Ratios are selected from the list as FD2 155HP Auto.
I will check on the datalog and speedo comparison..
IcEMoCHa
Post by IcEMoCHa »
I have checked the speed of datalog and speedo and they seem to match.. Any other ideas? Does the R18 auto in the US face this problem?..
goodspeed
Post by goodspeed »
any news bro?
nizan5567
Post by nizan5567 »
Hi, can i know the actual gear ratio for fd2 asia AT.Now i have problem speed meter not match with actual speed and 1 more thing my auto cruish not funtion.any advice for this problem
goodspeed
Post by goodspeed »
Bro read my post. On the gear ratio and speed adjustmeet.
