Swapping S300 from a full fram PR3 into a P72JDM
Ebola_One
Post by Ebola_One »
Just trying to explore avenues for getting an ECU up and running in light of a problem with my current ECU, was wondering if I can swap my S300 from my OBDI PR3 ECU (full frame ECU) into a JDM P72 (small frame ECU)
Is it possible for me to do this? I see that the S300 has a heatsink on one of the chips and the S300J has no visible heatsinks.
Thanks for your help.
No, an s300 will not fit in a small case JDM ECU. You must use a s300j in the JDM ECU.
