Launch and activation RPM
mov
Post by mov »
Hi
Tried to searc on here but got no answers
anyway if launch control settings my Launch is set to 4006rpm
what should the activation rpm be 4500 or 5000rpm
and what does it actually do/mean the activation rpm
AREA876
Post by AREA876 »
If your car is boosted, this is the rpm which fuel and ignition changes would start for anti log to work.
mov
Post by mov »
AREA876 wrote:If your car is boosted, this is the rpm which fuel and ignition changes would start for anti log to work.
Car is not boosted so what should i keep it to
AREA876
Post by AREA876 »
It can be same as your launch limiter rpm, just make sure fuel enrichment and ignition timing are 0.
JimL
Post by JimL »
Optional rpm limit when car is stationary. Used to improve launches.
IE: you're at the drag strip, you know you can launch your car from 5200 rpm. this setting allows you to await the green light with the gas-pedal to the floor because you have lowered the rpm limit. When the car passes x mph (rolling speed) the rpm limit is raised to your normal setting.
Re:
JimL wrote: Thu Feb 03, 2011 6:23 pm Optional rpm limit when car is stationary. Used to improve launches.
