NEED HELP SELECTING HONDATA FOR MY B20VTEC
jdmintegra31558
Post by jdmintegra31558 »
I HAVE A 95 INTEGRA WITH A 99 B20 BLOCK WITH 99 B16A HEAD. WHAT DO U NEED TO KNOW TO SELECT THE RIGHT HONDATA? IM RUNNING P28 CHIPPED ECU NOW. I WANNA DO ALOT OF UPGRADE TO BE FAST. I JUST BOUGHT THE CAR A YEAR AND A HALF AGO. ANY HELP IS APPRECIATED. THANKS
~JDMHONDAB20V~
Luke
Post by Luke »
take the S300, that allows tuning without buying any other equipment (only a wideband and some sensors you need anyway), it has datalogging on board, so everything you need for tuning.
best regards Lukas
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
