Decrease INJ below Red...(10.00)
kornshadow097
Post by kornshadow097 »
Anyone Know how to decrease the INJ phase? Is it just increasing fuel in the duty?
Or is there another method?
You are going to have to be much more spcific as I don't understand your question.
kornshadow097
In the k pro software for my data logs, I get my INJ value above 10(ms) and it turns red which I assume is bad.
My question is how do I lower the inj phase duration?
That is a display setting you can set it to whatever color or setting you want.
If you are maxing out your injectors then you need larger injectors.
kornshadow097
I read under the help menu on the k-pro software it says I only need larger injectors if the duty is close to 100% and so far I barely hit like 70%. the INJ (ms) is the one turning red..im guessing its a bad thing?... or is it not?
Don't worry about the color. It is something that you can set to whatever you want.
kornshadow097
Alright, I'll just ignore the Red numbers then.
