02-04 stock wideband o2 voltage to AF ratio table
mikegedge
Post by mikegedge »
Is there anyway I could get a copy of the voltage table used on the 02-04 RSX Type-S for the stock o2 sensor.
I'm trying to read the o2 voltage into my PLX gauge without having to buy their separate wideband and doing all that work.
kb58
Post by kb58 »
It's probably faster and more accurate to feed a variable voltage into the O2. Record both the voltage and O2 ratio and presto.
Mid-engine K24 turbo Locost, http://www.midlana.com
That will not work. You must use the proper sensor from PLX Devices. THe stock sensor is current based, not voltage.
