05-06 K-Pro Adapter pin removed
donofdade
Post by donofdade »
I don't know how but 2 pins have fallen off from the adapter harness and now I am getting a knock sensor malfunction error code.
Is it possible to plug the pin back in?
Do I need to replace my adapter?
How do I know where both pins plug into?
Thanks for anyone who answers me in advance !!
If the harness is damaged you would need to replace it. The cost to replace it is $150 with the return of the old harness and ECU for inspection.
donofdade
Post by donofdade »
Spunkster wrote:If the harness is damaged you would need to replace it. The cost to replace it is $150 with the return of the old harness and ECU for inspection.
Not sure if its damaged, here's a picture.
IT is damaged and would have to be replaced.
