S2000 Kpro's all the same?
dagle
Post by dagle »
Are the 00-05 S2000 Kpro's the same as the Kpro's for 06-09 in terms of the actual Kpro ECU itself. In otherwords, if an 06-09 Kpro setup were stripped of its dual adapter harness, would it be the same as the Kpro for 00-05?
Would love to be able to use Hondata over AEM. Thanks in advance!
Silas
VtaK
All K-Pro boards are the same, but an ECU that is prered for one application will not work in another application. WHat you propose will not work. A custom adapter board is added to the ECU for use with an 00-05 S2000.
dagle
Post by dagle »
Ahh. Understood. thanks, guess ill have to get my hands on a PRB ECU or Kpro then. :)
VtaK
