info required on s300 chip
sean brady
Post by sean brady »
how is things ime only new to the site and got a few questions for someone who got the answers!!!!!!i built a d14a4 bottom end with a d16z6 head which is ported and polished and am curently running it on standard dual carbs but would love to put it on injection but this is wher it gets complicated its a 91 civic and i put a obdo dash wiring loom in it so if i want to go vti i wont av ta change the loom again but can i get a s300 chip for ths 1.6.dohc vtec ecu 88-91 europen and if so will it run the 1.4 in the 1.6 ecu if i get it mapped or do hondata do a cheaper chip that would suit me this is for my rally car and any info would be of great benfit thanks for takin the time to read my problem i have came across[/b]
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
sean brady
em what price would that cost me in dollars posted to ireland for the s300
Hondata does not sell directly. You will have to contact one of the European dealers listed on our website.
