S2000 FlashPro Boost Control
In the past many have people have asked us when boost control will be added to the S2000 FlashPro, but because the S2000 ECU does not have a spare PWM output (like the Civic Si) we have not been able to do this.
However, we have looked closely at the S2000 ECU and found that we can modify the ECU to enable a PWM output on an unused pin. Thus you can have boost control with the S2000 FlashPro.
For S2000 FlashPro boost control you will need to do four things:
1. Send in your ECU to Hondata for modification. The form you need to fill out is found here.
2. Obtain a suitable boost control value. If you wish you can buy one from Hondata at the same time you get your ECU modified.
3. Download and install the FlashPro beta software - available later this week.
4. Wire up the boost control solenoid as per the help file
Fine print:
- Currently only US S2000 ECUs have been tested, but this should work for international S2000 ECUs.
thesilverbullet
Re: S2000 FlashPro Boost Control
Post by thesilverbullet »
Nice!
Any plans to add an option for nitrous control to fpro manager and use the same output?
- could add a user check box to select boost or nitrous control for the new output...
'23 RDX SH-AWD
'07 S2K w/ JVT header, Berk 3" header back w/ TP Exhaust, AEM V3 CAI & Flashpro
'02 RSX-S w/cai/exhaust/dcrh/kpro - SOLD
