Random Ignition Cut
jake1191
Random Ignition Cut
Post by jake1191 »
Recently my car started to do what i thought was boost cut. So i lowered the boost with my MBC and have the car hitting 5psi. My tune was made on 7psi and has been running great for about a month or so. Now for some reason at random times in any gear under a high load/boost my car will just fall on its face until i let off the gas and go back to it. I have only had this happen at 1/3rd throttle or more.
Any ideas what it could be?
AREA876
Post by AREA876 »
You need to post your calibration and a datalog of the problem
jake1191
Post by jake1191 »
The issue is in this datalog that i caught happens at 5000rpm and it is an ignition cut.
I know my wideband readings are off but that is mainly due to open exhaust at the current time and the sensor being close to the outlet.
jake1191
Post by jake1191 »
Any ideas? This is driving me nuts
That datalog shows you reving past 5000 rpm without any problems, can you give the exact time index you are referring to?
