Quick question about highest rpm in fuel tables...
Axix23
Post by Axix23 »
Lets say your rpms go up to 8500rpms on your fuel tables in your kal.. And you set the rev-limiter up to 8600rpm.. Does the ecu stop reading the fuel tables and doesn't add any fuel above 8500rpms or does it still read from the values of the last line which is the 8500rpm fuel line values?
Thanks...
It will continue to use the highest value.
You can edit the RPM index.
Axix23
Post by Axix23 »
Hondata wrote:It will continue to use the highest value.
ok, thanks..
Is there anyway to add an additional rpm line without changing any of the other fuel cells? I know you can delete and edit... But there isn't an option for add... :(
no
Axix23
Post by Axix23 »
ok, thanks.
Right click and select 'add rpm index' will add an index and shuffle all the fuel/ignition values around so that you don't need to change them.
