Secondary Table wont Switch
kerndog
Post by kerndog »
My car is a 97 Civic DX Hatch, H22A, P28 ECU. details about the car and the switches that control the secondary tables are in the notes, under paramaters tab of my cal.
I cannot get the Secondary Tables to activate, I have tried "always on" and nothing happens. I have tried with different switches both regular and inverted in the parameters. I have tried "tables follow secondary" checked and un-checked. No matter the way I try, I cannot get the Sec Table (at bottom of sensors tab) to light up indicating I am on secondary tables. I can confirm there is no change in AFR if I remove 50% fuel from the secondary table and hit the switch or leave always on.
I want to run pump gas on one table and E85 on the other table, this working properly is an important part of having the freedom to fill up on either and just flip a switch for the right tune and more boost on the corn juice.
H22 GT3076R E85, EK Hatch, Dyno Shootout Car...
603 WHP, 565 WHP, 631 WHP, 596 WHP, 600 WHP, 610 WHP, 631 WHP, 560 WHP, 578 WHP
different dynos, different days, different altitudes,same set-up, bottom line...~600ish WHP come get some!!!
locash
Post by locash »
Strange.. For the hell of it, try setting the tps activation to 1% and tapping the throttle to see what happens.
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
Don't ever use 0 as a minimum for engine speed or engine load, the computer does not like to see zeros for these values.
kerndog
Post by kerndog »
I upped the kpa to 10 and the mininum RPM to 100 and it works perfect thanks Spunkster!
I also tried locash's recommendation and nothing changed. I didnt try the load or RPM seperate though.
Thanks for the support!
