OBD and logs
Croc999
OBD and logs
Post by Croc999 »
Hi,
2 question about Flashpro.
i use 1.1.8.2 intl version for my Euro S2000.
1. i recorded few logs today and i see them at the Flashpro window but when i download or save them they come as 1k file with zero time.
i now recall that i forgot to stop datalogging before turning engine OFF.
any way to retreive those logs correctly?
2. i want do OBD II diagnostics.
Help file say there is a window for that - i can't find it.
pls help.
Thx,
Gennady
List step by step exactly how you are going about saving these datalogs.
OBD2 diagnostics is under the online menu at the top of the screen.
Croc999
Post by Croc999 »
regarding OBD - thx.
i will try this next time i'm with the laptop near the car.
regarding logs:
first of all - usually they downloaded OK.
but then - usually i press the button to stop logging before i turn ignition OFF...
this time i tried several methods:
1. select all logs, click on "save as", renamed each file, "compression" option is checked
2. select one log, click on "download"
3. select one file, saved it with its original name, "compression" unchecked.
Download and install the new beta from the downloads section of our website and see if that helps.
Croc999
Post by Croc999 »
OBD works OK.
logs still don't downloaded OK.
shall i give up?
This appears to be something with the new beta version, we are looking into it.
Croc999
Post by Croc999 »
thx,
BTW - right after flashing with 1.1.8.2 i've got p1412 CEL.
my car is Euro 2007.
this problem remains also with 1.1.8.3 and "euro 2006+ stock equivalent" tune.
i'm looking into air pump, its relay and etc.
this is very rare problem and my car did only 56,000km.
this looks too much of coincidence - so i'm wondering maybe something have changed in Flashpro that could cause it...
bgh_187
Re: OBD and logs
Post by bgh_187 »
As the above comment, i flashed my S2000 today with the stock tune map using 1.1.8.5 software.
I to now have fault code P1214 which i believe is related to the secondary air pump.
Is this a problem that Hondata can fix or tell me how to fix?
Croc999
Re: OBD and logs
Post by Croc999 »
is your S2000 euro version or american?
Euro S2000 MY07 F20C2
bgh_187
Re: OBD and logs
Post by bgh_187 »
Sorry forgot to add that it's a euro (UK) S2000
Cheers.
Croc999
Re: OBD and logs
Post by Croc999 »
my code is P1412.
is your the same or P1214?
we discussed this here:
http://www.hondata.com/forum/viewtopic.php?f=29&t=12595
bgh_187
Re: OBD and logs
Post by bgh_187 »
Yeah I've just got it back to front, it's the same fault as you posted.
Thanks for the link as well, I'll be eagerly awaiting the next release to get rid of this problem.
Thanks.
Croc999
Re: OBD and logs
Post by Croc999 »
well, if its 2 of us - i think it's 99.999% problem cause by new FPM.
i trust Hondata they can figure this out.
i guess they need updated Euro S2000 electric diagrams.
i don't have them as i nevers saw them for sale (i have US ones).
let's hope Hondata can use their connection at Honda to get required tech info.
bgh_187
Re: OBD and logs
Post by bgh_187 »
Yeah, well this is my first time flashing the car with the flashpro as i just recently bought it.
Did older versions of the flashpro manager flash euro S2k's without this problem showing up?
If it did then it should be easy for them to pinpoint what has caused this to show up.
Croc999
Re: OBD and logs
Post by Croc999 »
no.
i started from 1.1.7.4 and it was fine.
the problem first appeared at 1.1.8.4.
