IAT, ECT compensation for ignition in FD2R
engjoo
Post by engjoo »
Dear Hondata,
What tradeoffs will we have for not having the IAT and ECT compensation for ignition for the FD2R ?
Does IAT/ECT compensation for ignition exist in the factory calibration of the FD2R?
Re: IAT, ECT compensation for ignition in FD2R
I've never had to change these tables.
Use the race calibration if you want to change the ECT and IAT ignition compensation.
engjoo
Post by engjoo »
Hondata wrote:I've never had to change these tables.
But they do not even exist to begin with. Or is it 'there' but u don't 'see' it ?
Make sure you go to Options and click on show advanced parameters.
engjoo
Post by engjoo »
I did that but IAT/ECT compensation for ignition is not there:
Hondata wrote:Use the race calibration if you want to change the ECT and IAT ignition compensation.
engjoo
Post by engjoo »
Why are there only 10 load columns in the following calibration?
Civic-Si-RRC1
Civic-Si-RRC1-Reflash
How do import tables from the above into the race calibration?
I have seen that the knock tables are also different in the race calibration. Which is the correct one for the FD2r?
The RRC calibrations are not expanded for boost - you'd need to use the race calibration for forced induction.
Tables can't be directly imported because of the difference in column count, as you probably have found out. If you want the RRC knock ignition limit tables in the race calibration then you'll need to copy and paste the first 10 columns, then replicate column 10 across the rest of the table.
engjoo
Post by engjoo »
Hondata wrote:The RRC calibrations are not expanded for boost - you'd need to use the race calibration for forced induction.
Why are the knock tables different ? How was the knock tables derived? Which one is the closest to our Factory knock tables?
The RRC calibrations are closest to factory.
