Boosted LSVTEC cutting off in 4th gear
Clint_001
Post by Clint_001 »
Hi Guys,
I'm having a weird problem yesterday at the races. My 1st qualify round went all the way from 1st through 4th gear without any problems, but on the 2nd round I raised my launch rpm to 7500rpm instead of 7200rpm.
The car ran good in 1st through 3rd but kind of hit a rev limit around 7300rpm.
My setup is a 83mm LSvtec turbo running ID1000cc injectors 6765 turbo, ITR cams, S300, Hondata 4 bar map sensor, walbro and bosch inline fuel pump tuned on C16
I'm clueless to what could be causing this. Please let me know what you guys suggest.
Re: Boosted LSVTEC cutting off in 4th gear
I have seen something similar from a combination of high rpm (over 10,000) and distributor noise (often aftermarket). The ECU detects errors at a rate not high enough to give a check engine light, but seems to run in a partial limp mode.
Clint_001
Post by Clint_001 »
I'm running a M&W pro 10 ignition box with a crane ps92 coil.
I've had miss firing issue at first with the stock ignition system but once I switched to the M&W box it went away and didn't have any issues until yesterday. Not even on the dyno when I dynoed in 4th gear.
@ Hondata or any experienced tuners: Have you gone through my parameters to see if there could be anything unusual that could be causing the cutting off in 4th gear?
locash
Post by locash »
Your TPS reading went away, probably causing the issue..
-joe
Locash Racing
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
