Will this O2 sensor work with a PRB K-Pro?
Payne
Post by Payne »
My Ariel Atom came with this O2:
Denso
Du5
211200-2650
12k11-09
Usa
Will that work with an 02-04 PRB ECU?
Thanks,
Jason
2011 Ariel Atom - K24 Powered
2006 Range Rover Sport Supercharged - tow, snow, and show
Re: Will this O2 sensor work with a PRB K-Pro?
What was the original ECU in the vehicle?
Payne
Post by Payne »
It's a 2011 Ariel Atom, with a K20z3 style setup. So the original ECU is a K20z3; however, I bought just a roller and am putting in a K20A2 head/harness/ecu on an ERL built K24A2.
Thanks,
Jason
You should just use the FlashPro to tune this and not swap the haness and ECU type.
Payne
Post by Payne »
Spunkster-
I've already got my ECU, wiring, TB, etc to run everything as a PRB. I'm not going to be using a Flashpro. All I need to know is if the newer O2 sensor is compatible.
Jason
