Possibility to include Secondary Air Injection Delete?
Dan1987
Post by Dan1987 »
Hey,
I was wondering if it would be possible to include an option in the next update of FlashPro Manager to delete the Secondary Air Injection systems used on EDM S2000's with out throwing a CEL?
I know AEM have encorporated this into their engine management system and was wondering if it could be done with FlashPro?
This would allow us to run a wider range of intercooler set-ups for our supercharged and turbo'd cars as all the air pump etc is situated down at the front left of the front bumper (currently limiting area's we can route our intercooler pipework).
Many Thanks
Dan
Croc999
Re: Possibility to include Secondary Air Injection Delete?
Post by Croc999 »
i would like to have this too.
Euro S2000 MY07 F20C2
2006 onwards US vehicles do not have an air pump. If the Euro S2000 has this pump, unplug it and tell us what error code(s) you get.
Croc999
Post by Croc999 »
yes, Euro 2006+ S2000 has this pump.
i will try and let you know.
actually i have now CEL 1412 which is not documented in US Honda service manual.
according to UK s2ki wizards it's related to air pump relay - so i ordered one and waiting for it to arrive.
currently air pump doesn't work.
so you might want to check this error code too.
this CEL started immidiately after reflash new tune with FPM 1.8.2.
i actually thought it might be FPM related because this is too much of the coincidence and we pulled the current relay out and looks good.
any chance that adding Boost control to FPM messed something for Euro s2k?
What ECU pin controls the air pump?
Croc999
Post by Croc999 »
wow - that's a tough one (at least for me).
looking at this Honda's guide it looks like A31.
full discussion is here:
http://www.s2ki.com/s2000/topic/265541-error-code-1412/
thx a lot for looking into this!!!
really appreciate this.
Thanks. I'll look at this for the next release.
phantom_
Post by phantom_ »
hello,
i recently upgraded my FPM version from 1.1.7.4 to 1.1.8.5 and uploaded my final calibration to the car which is a 2006 EDM S2000.
i immediately received a CEL as P1412. i guess this is related with secondary air injection system. i have never received such a CEL during my uploads with FPM 1.1.7.4.
does Hondata think that it is related with the latest version of FPM?
i am using a test pipe. i think it will be very valuable to have secondary air injection delete feature in FlashPro.
2006 Euro S
Croc999
Post by Croc999 »
you're the 3rd person who reports here exactly the same issue (Euro S2000 + 1.1.8.5 FPM) - so it's probably caused by FPM.
Hondata, when do you think you will have fix for this?
phantom_
Post by phantom_ »
croc999,
so you think this is a bug related with FPM 1.1.8.5? if so, is it possible to rollback to 1.1.7.4 which is the previous official release?
however, please note that latestes version not only upgrades FPM but also firmware of the FlashPro hardware. so i would like to ask Hondata if previous release rollback is possible?
2006 Euro S
bgh_187
Post by bgh_187 »
I'm the other person that has highlighted this issue on this forum.
I've now had my car professionally tuned and the guy tuning it said he tried to use the older revision software that doesn't have this problem and it wouldn't work.
Looks like we will have to wait for hondata to fix this issue.
Another problem that I came across with the beta release was when I was data logging the afr would show that my car was heavily over fueling, but when the dyno age readings were done the car was actually running lean.
Croc999
Post by Croc999 »
phantom_ wrote:croc999,
i tried to rollback but it didn't help - probably because Flashpro device firmware doesn't foll back when you use older FPM software.
Dan1987
Post by Dan1987 »
I now have this CEL after using the latest version :(. Please fix this soon!
Croc999
Post by Croc999 »
i think it would help them if you specify what's your car...
Dan1987
Post by Dan1987 »
Croc999 wrote:i think it would help them if you specify what's your car...
EDM S2000..like i said in the opening post.
