Datalog problems
jdm inc
Datalog problems
Post by jdm inc »
I am having problems with the s300 in a p28 ecu when the car is running and I hit the datalog button or f10 it will datalog for about a min or so and quit. It still says online but the display is just frozen.
I would have to unplug and replug the usb cable to get it to datalog again correctly?
it uploads and downloads fine.
I am running version 1.5.3.0 beta
i uploaded the new calibration on to the new firmware and uploaded it to ecu.
I have updated the usb driver.
i am running ngk 9 plugs BKR9EIX
If anyone could give me some insight i would greatly appreciate it.
Thank you.
T1 Tuned 765@34lbs :) pb 9.75@154 fastest mph 155
http://www.t1racedevelopment.com
http://www.youtube.com/watch?v=lRwE0k9MIl0&feature=plcp
Re: Datalog problems
What vehicle is this in and what has been done to it.
jdm inc
Post by jdm inc »
Spunkster wrote:What vehicle is this in and what has been done to it.
in a 93 honda civic.
fully built gsr
Block
Golden eagle sleeved b18c
Arias 9.1 pistons
Eagle rods
Micropolish gsr crank.
Oem bearings
Head
Gsr head stock port
Skunk2 pro1 cams and gears
Rev valve train
Victor x manifold ported to 74mm.
Rpm service 74mm TB
Oem timing belt
Turbo
BW s372 w/race cover
Twin Tial 44mm WG
SLS topmount
4”exhaust
SLS Custom backdoor intercooler 24x12x3.5
Tial 50mm BOV
Gsr lsd tranny
Exedy twin disk clutch
Electronics
Hondata s300
Plx m300 wideband
m&w Pro 10 mounted between the shock tower and headlight away from the ecu.
Suspension
PIC. 12k F 18K B
Traction bars
Blox rear lower control arm
Innovative solid mounts
Fuel
-10 Feed -8 Return.
Dual bosch 044’s
ID 1000cc injectors
AEM Fuel rail
Weldon fpr
It might be the aftermarket ignition system. Try returning the ignition to stock and see if the problem goes away.
jdm inc
Post by jdm inc »
ok ill give it a try and see.
what odd is that it never did it before.
Could it be the usb cable?
bb4lude
Post by bb4lude »
I am having the exact same problem with my datalogs, also the display for the sensors (rpm Tps af e.t.c) freezes after 1min. I have a stock ignition system. Only thing I did notice was q34 was burned on my P72 ecu, I believe this is for the iabs which I have always had disabled by disconnecting the vacuum hose anyway. My ecu is 2nd hand so I think Q34 got damaged by last owner. Could this be a cause perhaps?
Try the ECU in a known good vehicle and see if the problem goes away. If it does you know it has somethign to do with the wiring or components in your vehicle.
TheWickedOne1
Post by TheWickedOne1 »
also, if on-board datalogging is enabled, disable it while your trying real time. Also use the USB cable that is provided by Hondata as it helps with the reduction of EMI Noise since it has ferrite cores on it.
bb4lude
Post by bb4lude »
Ive tried disabling on board datalogging, and im using the shielded usb cable supplied by hondata. I dont have the luxury of a spare car to try it on unfortunately.
Datalogging ran for a few minutes before freezing again today.
I did notice that im not getting any EGT readings. Then I realized i dont have an EGT sensor, it was left in my old cat when i got a decat fitted.
V-Spec race development
Post by V-Spec race development »
While data logging, Are you using or do you have anything plug into your cigarette lighter? it's doing that same thing what you're talking about when I was using the laptop's car charger.
