Calibration with RC370 injectors.
AltaSiR
Post by AltaSiR »
I notice the list of calibrations doesn't include a 370cc injector option for the B16A supercharged. Is it possible to select the 440 option and then manually change the fuel trim parameters from 440 to 370? Will this change all the fuel parameters to the 370cc injectors then?
Thanks for any advice.
Re: Calibration with RC370 injectors.
You will have to get it tuned properly on the dyno to run with different injectors as they have different flow characteristics. 370s may not be big enough.
AltaSiR
Post by AltaSiR »
JRSC runs there FMU set-up with stock injectors at 6-8psi boost, so why wouldn't 370cc be enough with Hondata at low boost? I know Greddy sells there turbo kits with 370's so I thought they would be enough. But, I trust your opinion and if you think I need at least 440's then I will swap them out.
