Stall at 5000rpm
VTiSpec
Stall at 5000rpm
Post by VTiSpec »
when I hit the pedal fast to WOT engine will go to around 5k rpm and stalls. If I hit it progressively it goes all the way up to 8k or more. it does that stationary and rolling.
I did datalogged it, but i forgot to saved it, anyway what called my attention, duty and inj were 0, but tps was around 85 as well as rpm 4800.
Re: Stall at 5000rpm
You need to post the calibration and a datalog showing the problem.
VTiSpec
Post by VTiSpec »
I have to do that tomorrow afternoon, in the meantime I forgot to add that afterward I disabled "Lean Protection 1" and tested ok stationary, but rolling when I change gear engine stalled.
VTiSpec
Post by VTiSpec »
attached calibration, I don't see the need to send datalog since it does not stall anymore. Engine hesitates when shifting gear (as I mentioned in my last post). this is a race car.
thanks,
VTiSpec
Post by VTiSpec »
additionally,
B16A2 engine
83mm bore pistons
type R head
310cc injectors
stock cams
do you still want a datalog during shifting?
