help! Hesitation when swithing into gears
gsxr750
Post by gsxr750 »
can some one help me. what am i doing wrong, when ever i switch into gears it my car dips and hesitates when chaning gears..
could someone fix it thanks..
Re: help! Hesitation when swithing into gears
Has this been tuned on the dyno?
TheWickedOne1
Post by TheWickedOne1 »
looks like it needs to be tuned. There's lots of stuff going on in the log and calibration that shouldn't be. I would recommend bringing it to a competent Hondata Tuner in your area before you hurt your motor.
gsxr750
Post by gsxr750 »
not Dyno tuned only street. We don't have a Dyno in the island. Can u give men some pointer to where to start?.. Should I start a fresh calibration, turn down the boost?
TheWickedOne1
gsxr750 wrote:not Dyno tuned only street. We don't have a Dyno in the island. Can u give men some pointer to where to start?.. Should I start a fresh calibration, turn down the boost?
What type of wideband are you using ? The last thing you want to do is make changes with no data to support your changes.
burmese434
Post by burmese434 »
On the datalong it hard to tell. Try doing some 3-4 gear pulls so traction problem really won't be a issue. The last time I have that problem, my exhaust had a leak making the wideband read wrong and come to find out it was really rich in between shifts.
