can`t edit values in colum 10 on WOT low & high fuel tables
tu5j4
Post by tu5j4 »
I can edit all the colums on the main fuel tables, ignition tables, cam tables, but not the WOT low and high fuel tables.
Colum 10 shows 1 Kpa on both tables and I cannot change it. The edit-change-delete parameters appear in shallow letters, not in bold letters. All the other colums gradually go up to 99 Kpa but the WOT tables go to 92 Kpa in colum 9 and then goes to 1 Kpa in colum 10.
Is there a way I can somehow solve this? I´m afraid the engine won´t stay into the correct afr range when i´m on full throttle in colum 10.
Re: can`t edit values in colum 10 on WOT low & high fuel tab
From help about what version of software are you using, and please post your calibration.
tu5j4
Post by tu5j4 »
I`m on version 1.1.8.5.
My map calibration:
Options menu, Settings, Units Tab. Change 'Pressure Unit Base' to absolute.
tu5j4
Post by tu5j4 »
All fixed now. Thanks for the swift response.
