need some good insight
danyo655
Post by danyo655 »
any ideas what would make oil burn thru the exhaust when i unhook the pcv valve?, did compression test all is good, rebuilt turbo and still all is good, im running a 2nd gen tsi t25 turbo on my f23a1 accord. only pushing 8- 10 lbs daily, never more.
HondaTechn303
Re: need some good insight
Post by HondaTechn303 »
Could be ur Turbo Oil Seal.. It's a big O-ring.. My friend had the same problem with his B18c1...
You need to have the PCV connected or this can happen from build up of pressure.
danyo655
Post by danyo655 »
learned something new, 80 psi of oil to a turbo isnt cool, haha, found an oil restrictor and all is good except i cant get the wastegate or boost controller to regulate boost at all, both wastegate and boost controller are functional as i tested them on a friends car.
