Datalog graphs?
johan78
Datalog graphs?
Post by johan78 »
Hi! I'm sure there is an answer for this somewhere in this forum, but I couldn't find it. How do I get a graphic chart of my datalog? All I get is a realtime playback of my log with numbers running. Aren't I supposed to get a graphic display of for example cam angles? Am I missing something? And am I supposed to run in open loop for datalogging even if I'm just trying to log ignition advances and cam angles?
Honda Civic Type-R EP3 Euro
Re: Datalog graphs?
You can drag the line back and forth in the graph window and it will allow you to see what is happening at the same time in the other windows. Just arrange them so you can see them at the same time.
johan78
Re: Datalog graphs?
Post by johan78 »
Thats the problem. I cant find a graph window. Is it supposed to be open automaticly when i open a datalog file? Or should i find it in under the windows tab? I tried to look for it but cand find it.
edit
never mind. i can't belive i didn't find it before...
