Prc vs Prd ecu
Knox
Prc vs Prd ecu
Post by Knox »
Hello, i'm new on hondata forums. I need to find the difference between jdm prc and prd ecu. Is the only difference is prd ecu cuts at 8900rpm and prc 8700rpm ? If I use prd ecu on my 2003 jdm integra type r, will it lose power or gain ?
Please reply and help me. Thank you
Re: Prc vs Prd ecu
Using either with the K-Pro will make it fully tunable and everything is adjustable.
Knox
Re: Prc vs Prd ecu
Post by Knox »
I know that using kpro with both is incredible but can you compare the both prc and prd ecu to me. All helps are appreciated. Thanks.
Re: Prc vs Prd ecu
I do not have the specifics of the stock ECUs.
Knox
Re: Prc vs Prd ecu
Post by Knox »
Thank you.
If anyone knows about prd vs prc ecu reply please.
