K pro not working, Usb driver trouble, Please help!!
pr3lude
Post by pr3lude »
Kmanager V1.5.0
2004 Honda Civic SI
2008 K24 Tsx motor/06 Civic Si 6 speed tranny
CAI, Skunk2 Manifold, Skunk 72mm tb, Hytech headers, Exhaust
Im having trouble with my k pro, it doesnt wanna work on neither of my laptops(Windows 7/xp). I keep getting the balloon saying USB Not recognized. I went on Kmanager and updated the Usb driver but still doesnt read. I have the latest version of Kmanager V1.5.0. Please help me troubleshoot this problem. Thanks
Re: K pro not working, Usb driver trouble, Please help!!
What directory are you pointing it to to install the driver to when you go through the installation?
pr3lude
Post by pr3lude »
I tried pointing it to the kmanager but it did not find it and i tried through kmanager help and said update driver and it updates but still doesnt recognize it....
Spunkster wrote:What directory are you pointing it to to install the driver to when you go through the installation?
pr3lude
Post by pr3lude »
I did this and it did not find the drivers, it says the location you specified did not find the drivers....
Spunkster wrote:Manual Driver installation
http://www.hondata.com/help/kmanager/ma ... lation.htm
When you browsed your hard drive exactly what directory did you select?
pr3lude
Post by pr3lude »
C:\Program Files\KManager
Spunkster wrote:When you browsed your hard drive exactly what directory did you select?
What version of windows are you using, and what is the exact error message you are getting?
pr3lude
Post by pr3lude »
Im using windows 7 and it says usb not recognized and wen i update it, it says unkown usb and it doesnt find the k pro...
Spunkster wrote:What version of windows are you using, and what is the exact error message you are getting?
jdmssmep3
Post by jdmssmep3 »
I am having the same trouble with two different win 7 x64 systems. I plug it in, the computer recognizes something is plugged in but does not allow me to update the drivers. I have gone to update drivers, but it does not allow me to select any locations, just says its unable to locate the drivers. please help I have no car LOL
What does it show up as in the Windows Device Manager?
LimaRSX
Post by LimaRSX »
I am having the exact same problem.
Plug in the USB with the car in the on position the computer reads in device and managers "Unspecified Hondata K-series ECU"
I am using Win7 Laptop
When you do a USB test it says "No compatible USB devices found"
When you do an USB update it says "Error setting up inf file (Error:Access is denied.)" Then a second window pops up saying "Error updating usb drive"
This is quite frustrating as it is my first time trying to load up a kal and this will leave my car unable to run unless I can load this kal up...
For a $1000 piece of software, USB drivers should be a non issue or at least have it available to download!
Go to the Windows Device Manager, find the K-Pro listing there, right click on it and select update driver, then follow the instructions for the version of windows you have at http://www.hondata.com/help/kmanager/ma ... lation.htm (windows Vista and 7 are the same)
zeppdogg
Post by zeppdogg »
i got a brand new laptop with windows 7 and that procedure doesnt work. I had no other choice but to get a new 1 because the old 1 crashed.
onefstek
Post by onefstek »
So I been trying for the last few hrs to get this driver deal figured out. Got a new laptop put in the disk and I can open Kmanager. But it tells me that "Driver Not Installed" "Off Line"
I try to install drivers manually and still not work.
Anyone???
