Secondary O2 sensor disable not working 1.5 ver
sadvtec
Post by sadvtec »
I am curious if there is something I am missing or if this is a known issue with version 1.5 of Kpro? Basically after updating yesterday and reloading my most recent Kal. I am now blowing the secondary O2 sensor code even though it is unchecked in parameters/misc. Has anyone else seen this issue and is there a workaround out there?
K24/K20 swap in an 92 eg.
Previous version of kpro showed no codes it was not until I upgraded to 1.5 that the CEL came on.
Thanks for any help!
Re: Secondary O2 sensor disable not working 1.5 ver
Under 'Closed Loop' check that the secondary o2 sensor is disabled.
sadvtec
Post by sadvtec »
Perfect that worked thanks for the info!
