Kmanager 1.5.1.0 S2000
edomund
Post by edomund »
I updated my Kmanager today from 1.3.9 to the newest 1.5.1.0. I saw all the new tables (knock, wot comp). I don't want to tune these new tables right now.
1. Can I disable all these new tables? I see where you can uncheck the knock, but not the wot compensation.
2. Do all these tables work with the s2000 kpro?
Thanks,
Ed
AP2 S2000 Turbo
Re: Kmanager 1.5.1.0 S2000
1. No, the tables were always there and were used in previous versions, but could not be edited.
2. Yes.
edomund
Post by edomund »
Thank you.
So the values in the new tables I'm seeing are unchanged from previous versions, I can just see/edit them now.
If I don't edit the values I essentially have the same tune I had before, correct? I know this is a bit redundant, just double checking the values are the same as before.
Thanks,
Ed
AP2 S2000 Turbo
correct
edomund
Post by edomund »
Thanks,
Ed
AP2 S2000 Turbo
