EGT and Oil Temp Sensors
ITR1102
Post by ITR1102 »
Can I use any K type temp sensor? It is my understanding that the K type sensors all use 0-5v analog output. Is this correct? These are the units I have been looking at:
http://www.auberins.com/index.php?main_ ... cts_id=131
http://www.auberins.com/index.php?main_ ... cts_id=108
I read the Hondata instructions regarding the inputs to use and how to do that, I just want to see if I can wire the sensor straight into the ecu, or if a controller (such as the PLX or AEM) is really necessary. The goal is to datalog this in Hondata and view it on a Tunerview II.
Luke
Re: EGT and Oil Temp Sensors
Post by Luke »
no, you can't use those.
K-Type sensor work through an effect which is called "seebeck-effect". this is some strange behavior, which occurs, when 2 different metals are welded together and are heaten up.
then a voltage will be there. this voltage is so small, that it needs to be amplified. for this there are special amplifiers.
PLX has some devices, cost about 100$ and those can use k-type sensors and give a great 0-5V output.
look them up. they work pretty good. didn't have any issues with them yet.
best regards Lukas
We would recommend the PLX EGT controller too.
