OBDii splitter cable
Croc999
Post by Croc999 »
i have Scangauge2 - can i run it at the same time with Flashpro logging using OBDii splitter cable?
Thanks,
Gennady
Euro S2000 MY07 F20C2
phantom_
Re: OBDii splitter cable
Post by phantom_ »
hello Croc999,
this is irrelevant with your thread but; are you able to reset DTCs with your ScanGauge2? any problems?
are you able to read every parameter that ScanGauge is able to serve? like IAT or fuel economy?
2006 Euro S
I do not believe so - the OBDII CAN protocol only allows one device on the bus with the 'tester' address. However, you can try this and see if it works.
BTW, the ScanGuageII has a bug with working with the 29 bit CAN that Honda uses. I informed ScanGuage about this 2-3 years ago; but they are not going to fix it. With the bug the basic scanning functions work, but custom commands do not.
Croc999
Post by Croc999 »
Scangauge can reset CEL.
and of course dispaly them.
it shows most of the major parameters.
id doesn't show AF and S/L-FT and some other stuff - but it's very compact and easy to use.
i've tried friend's Auterra and it has much more options but very unfriendly user interface and very unconvenient connections (from below of the device).
