Corrected AFR - bottoms out at 12.25 - Stock AFR 10.14
terryl
Post by terryl »
Hi maybe i am missing something or doing something wrong ? - when i read my datalogs on a boosted s2000 the lowest corrected AFR only goes down to 12.25- stock AFR is 10.14 at this point which is not very helpful for road tuning - have added a datalog -calibration - this is on a 2008 euro s2000 using older 1.1.6.7 programme
Regards
terryl
Re: Corrected AFR - bottoms out at 12.25 - Stock AFR 10.14
Post by terryl »
Anyone ?
The corrrected reading is a calculated reading based on other parameters and was based on our own testing with independant widebands. When it is flat lining you have reached the limits of the stock sensor and will need to use an idependant wideband and or get it proprely tuned on the dyno.
donaldmejr
Post by donaldmejr »
so which one is correct the Corrected of the OEM one?
You should be looking at corrected
