FlashPro Bug??
donaldmejr
FlashPro Bug??
Post by donaldmejr »
Hondata,
I have verison 1.1.8.5 installed onto my computer and I was changing a few display ranges and I set both min and max to 0 and the software went into I system error loop and would not allow me to do anything with flashpro. I had to terminate the program to close it. If I reopened the datalog it would do the same thing again. The sensor I did it in was Map.
Re: FlashPro Bug??
Yes, setting the min and max both to zero causes a problem. We'll fix this for the next release.
Nike
Re: FlashPro Bug??
Post by Nike »
Hondata,
I have put R18 MT US ECU in canadian R18 civic. Everything (including FlashPro) is working, but the reverse is not blocked. It is possible to fix this?
Thanks.
Re: FlashPro Bug??
The US ECU is for a 5 speed transmission, and does not have reverse lockout.
Unsupported advice: Find an electronics student and get them to make a simple circuit which feeds the speed sensor pulse via a capacitor to the base of a transistor which controls the lock out relay.
Nike
Re: FlashPro Bug??
Post by Nike »
Hondata wrote:The US ECU is for a 5 speed transmission, and does not have reverse lockout.
It's no good =(
Thanks )
