Autotune. How does the S300 autotune work exactly ?
JDMCRX
Post by JDMCRX »
Curious how does this work ? I cant find any documents on it.
thanks guys
Re: Autotune. How does the S300 autotune work exactly ?
http://www.hondata.com/help/smanager/se ... b=autotune
To use Autotune, you must hold down CTRL-T.
I would recommend against using autotune as it usually makes quite a mess out of your fuel tables and you must then go back and smooth them all out.
IT is much easier to just make a recording of your run and make the needed adjustments manually after reviewing the datalog.
Johnny_9
Post by Johnny_9 »
need to update the help file on this, or fix it.
